OBDII Tuning and Emissions
Old Feb 7, 2007 | 10:26 AM
96RamAir's Avatar
I currently have an OBDI computer in my '96. If I put the stock OBDII computer back in, along with the correct knock sensor, can the computer be programmed to pass the emissions check? I don't have a problem with the visual check, it just won't pass once the hook up the machine to the computer port.
The last time I tried to get it to pass, there was an EGR error, along with O2 sensors. I assume I could have the EGR, air pump and rear O2's deleted in the program to make it pass?
Any suggestions?
Old Feb 7, 2007 | 01:30 PM
2000GTP's Avatar
Yes, you can disable all the codes to avoid the SES light. This will create a "not ready" status in the PCM. However, if you have too many of these "not ready" statuses in the PCM, you can also not pass that way. I would call your emissions testing center and find out how many you are allowed in order to pass.
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
88IROC_Z
Jul 22, 2015 11:38 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
