OBD2 - 1 swap without soldering PCM, and swapping KS?
... I tried putting the 3.9K resistor in line to pin 22 of the blue connector to simulate an OBDI knock sensor in the block. The car didn't start.
I want to get away from soldering INSIDE the PCM, and changing the knock sensor. Can I not put a resistor inline to the PCM wiring and have the OBD1 computer recognize it?
Right now a code is set on the OBD1 PCM.
Thanks in advance!
Thanks in advance!
Re: OBD2 - 1 swap without soldering PCM, and swapping KS?
Originally Posted by DR.ZED
Tell me about it Rob.... but it didn't.
