OBD1 swap info
Old Mar 20, 2004 | 11:44 PM
Nasty93TransAm's Avatar
OBD1 swap info
Here's the scoop, I have a 93 trans am with a obd1 conversion from a 95. I recently did the T-56 swap and hooked up the purple and yellow wires to the vss. I have a speedo reading, but it is obviously slow. 70ish on the freeway reads about 25mph. Can anyone help me get this thing wired right for the speedo to work. All the guages work fine minus the speedo and the trip. Thanks in advance for any help. If needed to make this easier you can email me at volvop544@aol.com
Old Mar 21, 2004 | 12:09 AM
Alvin@pcmforless.com's Avatar
what did you do with the wiring harness and computer from the 93 setup?
Old Mar 21, 2004 | 12:10 AM
i still have the harness missing some ends from the swap, and the pcm in the garage.
z28cam1993
May 29, 2015 10:17 PM
4586
Apr 27, 2015 06:08 AM
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
