OBD1 Conversion ?
Old Aug 6, 2007 | 09:03 PM
2xLS1's Avatar
OBD1 Conversion ?
Can someone explain why no wiring has to be changed doing a OBD1 conversion when 96-97 PCMs use PCM pin D7 and pin 2 on the OBD2 ALDL for the serial data and the 94-95 PCMs use PCM pin D30 and ALDL pin 9 (95s) for the serial data? Is it because GM left the ALDL 9 to D30 wire in the harness on the 96, 97 cars and just added the ALDL 2 to D7 wire.
http://shbox.com/1/1995_pcm_conn_d.jpg
Old Aug 6, 2007 | 10:49 PM
PCM C4 pin 30 to DLC pin 9 is still present with OBD-II.
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
