o2 problem ses at about 100 miles
Old Sep 8, 2004 | 11:01 AM
Plague's Avatar
I bought the car used. This is not covered under warranty. After driving about 100 miles the ses light comes on. I got the lower right bank sensor replaced based on the error code. About 100 miles later it happened again. Same sensor. Thought, maybe it was a bad one. Changed again. 100 miles later, you guessed it, SES on again. I havent checked it yet, but I am pretty sure that I know what it is. The car does have a non stock exhaust system that I did not install. Any ideas of what could be causing the problem?
EDIT: The exhaust I believe is from flowmaster. I may be changing this anyway.
Old Sep 8, 2004 | 11:31 AM
teke184's Avatar
Re: o2 problem ses at about 100 miles
did you clear the code? the code could be stored in the computer.
and this is the front sensor correct? or is it the rear...
what exactly is the code?
the catback would have no affect on the o2 sensors..
Old Sep 8, 2004 | 11:34 AM
Plague's Avatar
yes, the code was cleared
right rear sensor
low voltage (dont remember the exact code but I can get it)
Old Sep 8, 2004 | 12:27 PM
teke184's Avatar
rear sensor is the one that checks for bad cats...so it probably isn't your sensor...
or a wire got burned or cut somehow...and the intermitant thing is because the rear o2s are only checked under certain conditions...i use to drive with no cats and sometimes would do a week of daily driving before the SES light would come on.
Old Sep 8, 2004 | 03:28 PM
Plague's Avatar
any idea of what conditions they are checked under? I haven't taken it over 90 yet and have only reached 90 once, yet guys, it will be on the track soon. It seems to me to occur under normal driving conditions. I do drive through some traffic in the DFW area, but I am not speeding over 80 since the first time went on.
Thanks for you help so far too.
Old Sep 8, 2004 | 04:07 PM
Mindgame's Avatar
Sending this one over to "Computer Diagnostics" as I feel you'll probably get more input there.
Good luck.
-Mindgame
Old Sep 11, 2004 | 09:48 AM
Plague's Avatar
P0430 Catalyic Converter Definency Bank 2 was the error code
Old Sep 11, 2004 | 12:36 PM
2001NBMZ28's Avatar
Since you've already replaced the 02 sensor I'd call your local dealer about replacing your passenger side cat. Cats are covered under the federal emissions warranty for 8 yrs/80K. Do a search in this forum for "P0430" and "P0420" (Bank 1) before you call.
Old Sep 11, 2004 | 11:42 PM
Plague's Avatar
I did not know that about the warranty... thx for the good tip.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Jason Short
Jan 19, 2015 06:34 PM
