"Not a Licensed PCM"
Old May 18, 2003 | 07:58 PM
96speed's Avatar
Trying to flash the pcm with LT1edit, but it tells me the PCM is not licensed. I can read the pcm just fine, so I know the cable is good and it is not a connection problem.
It seems like I'm locked out of the pcm. It worked fine about a year ago .
Any ideas?
Ryan
Old May 18, 2003 | 08:07 PM
madwolf's Avatar
Did you have it reflashed at the dealer or changed the VIN?
Old May 18, 2003 | 08:34 PM
96speed's Avatar
I actually have 2 OBD1 pcms. I sent one of them to a friend of mine and he changed the VIN to my LT1edit VIN # so I could have it as a backup, but this is the original licensed pcm (to my LT1edit) as far as I know.
I'm about 90% this is the "#1" pcm, but would this be a likely problem if this was the corrected pcm?
Again, I can read it just fine. The VIN check out just fine, although it shouldn't matter, should it (for flashing)?
Ryan
Old May 18, 2003 | 08:41 PM
madwolf's Avatar
Yes it does matter and changing the VIN will not make it work with lt1_edit, because it doesn't look for the VIN only.
Old May 18, 2003 | 08:48 PM
96speed's Avatar
Ok..Well, Andrew did it so I can blame him .
Thanks Ion. I emailed Andrew and am confident he will get me fixed up.
Ryan
Old May 18, 2003 | 08:53 PM
madwolf's Avatar
Hmmm... maybe he knows something I don't know.
EDIT: This DID work on older versions of lt1_edit.
GREEN3112
Feb 10, 2019 09:19 PM
Rittmeister
Aug 7, 2015 01:13 AM
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
Jul 17, 2015 02:47 PM
