new -- TuneMaster
new -- TuneMaster
Hey guys just wanted to put this up here for some feedback and suggestions...
I’ve used tunercats and lt1-edit..
They are both good programs, I prefer tunercats... but after thinking it over I decided to put my hand in the pot...
So far it’s looking like this...
Scanner\Editor w/ WB input.
Key features:
Spark tuning <-- working on this one...
PE Tuning
Logging and log import (freescan etc)
User added tables and constants..
If you guys can think of functions or features let me know...
Now I know it nothing that isn’t already out.
But maybe w/ "scene" input this can become just what is needed..
and ill be making a webpage when i get a chance..
later
Key features:
PE Tuning
later
User added tables and constants...
How do you add tables and such when you are limited to what the computer has? You can't just 'upload' new tables into the pcm and hope the computer will magically look at them and say, oh, I use this!
Don't take this as a flame or anything... But what your talking about is FAR from easy... and would require VERY intense software testing and QA...
What are your qualifications to write such a program?
Again, not a flame, just not wanting to waste time going into everything when the outcome is just not possible
And also, would you charge for this, or give it away for free?
thanks,
jeff
thanks,
jeff
thanks,
jeff
thanks,
jeff
BTW, Tunercat has this feature already with the TDF Editor in case you didn't know.
Madwolf had it right...
There are still tables and constants in the PCM that have not been located...
And I was thinking it would be nice not to have to use a different program to add them...
I’m not knocking tunercats or lt1-edit...
They both fill a void that we had/have when mod'in our rides.
And i’m sure i’m not as good of a PCM hacker as the guys from tunercats of carputing... but from growing up around cars and computers i wanted to get a little more flexability.
For example, lt1-edit is locked to 1 VIN... and is a little more expensive then tunercats...
Tunercats isn't locked but is not designed just for lt1s...
Thanks madwolf for the help
Later
EDIT:
I have been programming in c/c++ since I was in high school
I have been into modifying and tuning the lt1's since late 01' when I install one in my 92 RS...
And I have been disassembling BIN files (bios, smartcards, etc) for a good bit of time now...
As far as charging for it or not. I don’t know yet.
Later
EDIT:
ahhh, of course... sorry
But yes, I'm all up for new programs
Is there a way to scan the pcm, for ALL tables and such?
I havn't looked into it at all... I just accept whats given to us via tunercat and lt1edit, hehe
I figured that much
But if its not too difficult to get at the hex, it wouldn't be hard at all to convert it to ascii and see what's in there... I have no experience with such low level devices at all however...
also, for anyone looking to write their own logging software, or see how it works... Freescan, Andy's program is open source and I believe he has it on source forge!
I'll definately be checking out those communication protocols when I have some time!
But if its not too difficult to get at the hex, it wouldn't be hard at all to convert it to ascii and see what's in there... I have no experience with such low level devices at all however... also, for anyone looking to write their own logging software, or see how it works... Freescan, Andy's program is open source and I believe he has it on source forge!
Originally posted by madwolf
He probably meant adding tables that are not in the software but which are existing in the PCM. (example, some tables like forced TCC threshold that was just recently added in tunercat).
If you have the hex values, can't you just convert it to ascii?
Again, I know little of hex... Aside from working with text files, and looking at them in hex editors to find funky hidden characters
Jeff
Jeff
