Needed-TunerCat file for a turbo application
Old Sep 11, 2008 | 07:30 PM
ctx97's Avatar
Hey guys, Starting to work on my turbo build, and figured I'd put this out early so more people may see it. If anyone has a tunercat tune for a turbo lt1 running slow boost, let me know. I need something to get it driveable to the tuner a couple hours away.
I can tweak the little things such as injector size, tire size, etc.
Thanks!
Old Sep 27, 2008 | 11:21 AM
ctx97's Avatar
ttt
Old Sep 27, 2008 | 04:13 PM
jchevy's Avatar
If your just trying to get it to your tuner it should be fine with the tune you have, just keep you foot out of it and your fine.
Old Sep 28, 2008 | 12:47 AM
dookie454's Avatar
There's a file avail in the attached thread... it needs a 2bar map and some other tweaks.. it's setup for larger cam, huge injectors, no MAF, no O2's, etc...
Or you could drive normal and use your stock file like Jchevy said
https://www.camaroz28.com/forums/sho...d.php?t=560089
Old Sep 28, 2008 | 09:15 AM
ctx97's Avatar
Yea, I was reading over that thread. Seems to be a little more then I need, and also way over my head at this point in the game.
Yea, I may end up having to limp it over there. Would all I need to do to be able to limp it that far is update tuner cat with my correct injector size?
Bails098
Aug 17, 2015 05:15 PM
NewsBot
Aug 3, 2015 02:40 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
whitehooptie
Jul 22, 2015 10:25 PM
NewsBot
Jul 8, 2015 06:47 PM
