need a sticker
Old Jul 3, 2008 | 09:41 PM
FAST96Z's Avatar
Angry need a sticker
ok here is the problem i have long tube deleted egr, air ,cats,and rear o2s now when i try to get a sticker they plug in to the pcm and it says not ready so the test cant go any further so i have a reject sticker oh ya ses light is not on my tuner tuned them all out but he has a new program from jett and even he says it aint to good so my ? is how do we fix this will lt1 edit help me get a sticker if not what will thanks guys
eric
Old Jul 4, 2008 | 12:14 AM
acre's Avatar
I'm not sure how having things tuned out of the PCM will affect this, but on a stock PCM you can get a "not ready" if you recently had the neg battery terminal off for a period of time or reset the PCM. The car has to have a certain amount of history data in the PCM before it will report on the systems that the inspection is testing. If it does not have enough history data it will report "not ready." I had this issue last time I got inspected and I just had to drive the car for a while to get enough systems to report for it to pass. Here in Houston, TX there are 5 or 6 systems that are checked and you are only allowed 2 or 3 "not ready."
Since I see you have a 96 I checked my 1996 Factory Service Manual, and this is what it says is the "Typical Drive Cycle" which should make the PCM perform all the tests and get rid of your "not ready" conditions:
Cold Start, Coolant Temp less than 122 F
Idle 2.5 min in D (Auto) or Neutral (Manual), A/C and rear defog ON
A/C off, accelerate to 55 mph, 1/2 throttle
3 minutes of steady state cruise at 55 mph
Clutch engaged (Manual), no breaking, decelerate to 20 mph
Accelerate to 55-60 mph , 3/4 throttle
5 minutes of steady state cruise at 55-60 mph
decelerate, no breaking, End of Drive Cycle
Total time of ODB II Drive Cycle 12 minutes.
You may not pass all the tests based on your mods and the tune you have, but you will at least get rid of all the "not ready" statuses.
Boss002
Jan 20, 2016 12:17 PM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
realistyc
Jul 28, 2015 07:32 PM
Boss002
Jul 9, 2015 03:33 PM
