Need LT1 edit program for CC306 with ported LT4 heads.
Old Sep 22, 2002 | 02:43 PM
11secondz28's Avatar
Anyone know or have a program I could download for my stock bottomend lt1. I have SVT 24# injectors, 1.6 rr's, CC306 cam, LT4 ported heads which flowed 306 on intake side don't rember exhaust side. Also compression is now at 11:1. Has stock LT4 valves and head gasket. Mac Shorties with no cats and true duals with two Bullet mufflers. It is a 96 Z28 M6 but has a 95 pcm in it with LT1 edit basic programing. I know I need a better program to mkae use of the bigger cam and better flowing heads etc.
Any help would be greatly appreiated.
BTW I spent a couple of hours doing searchs for downloads for LT1 eidt and found something close but doesn't have the same mods. I might have to use that program but maybe yall have some better ideas.
Old Sep 23, 2002 | 04:26 PM
Ernest's Avatar
Here's my suggestion,
If you can get some data scans of your car at the track (I use Datamaster, but maybe we can convert from things like Diacom or others), and post the .lt1 file, for the scan and post your current program file from LT-1 edit, we can take a look at it and see if there's anything we can do to tweak your program. There are several of us here that are familiar with LT-1 edit enough to help you tune the car a little. I'll gladly take a look.
-Ernest
Old Sep 23, 2002 | 08:02 PM
RichJ's Avatar
Have you checked here?
http://www.bfranker.badz28.com/LT1Edit/LT1files.htm
Old Sep 24, 2002 | 12:52 PM
csabatka1's Avatar
Here's some files that'll help you out:
Comp Cam 306, Ported Heads, Professional Tune
Comp Cam 232/242/114, Ported Heads
Old Sep 24, 2002 | 09:21 PM
Thanks yall. I downloaded the professional tune ported heads and CC306 cam. I am working on converting it to my current program which takes a while trying to match all the specs. I think I have it ready but am going to go over it once more to make sure everything matches perfectly would suck to have a jacked up program.
BTW I am very impressed that yall took the time to not only post the link for me but too show the link to the download. Thanks alot once again!
Old Sep 24, 2002 | 10:17 PM
csabatka1's Avatar
Not a problem. Good luck with you're tuning.
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
Bando
Aug 2, 2002 02:18 PM
