need help bad
need help bad
Ok i picking up a 1997 lt1 and t56 with the compeat wiring for the car, It runs a obd2 system and i was wondering what can i do to stream line the system ( when can i remove ) its going in to a 1969 chevelle so i dont have to worrie about passing air control.
1. What can i reamove ( air pump a/c ex...)
2. What wires can i remove
3. Can i relocate the power stearing pump ( drivers side )
4. How to by pass the v.a.t.s.
5. Any other mods i should think about to clean up the motor or increase hp.
you can remove anything not controled by the PCM.
And that would only be the A/C and power steering.
To get past VATS you need to have the PCM retuned and since u have to do it anyway you can get them to remove the crank AIR system and the EGR out of the PCM. Also the obd2 uses 4 O2 sensors, you can program 2 of them out if you want too so you dont have to run CATS
www.carputing.com
the software is $550 for OBD2 LT1 cars.
or you can pay liek $125 and have someone do it for you such as
www.madz28.com
www.madz28.com
colts0455
13
Aug 7, 2015 09:15 PM
zajones
Jul 30, 2015 02:18 PM
