need akm cable help
Old Jul 11, 2005 | 05:33 PM
blackztpi's Avatar
need akm cable help
i can't figure out how to get my computer going with my akm cable., i can't find out where to find the usb. help! please email me, or pm me.
Old Jul 11, 2005 | 05:47 PM
ZMAN Z28's Avatar
Re: need akm cable help
I did not know if there is a usb cable for datalogging or programming? Could you give us details on exactly what you got from AKM?
If you did what I did at first, I didn't buy the little adapter to go with mine, so it wouldn't recognize the cars computer. But my cable is the serial one.
Give us more info?
Z
Old Jul 11, 2005 | 11:31 PM
blackztpi's Avatar
i have the usb and the connector. i have all the right stuff. i got the computer to recognize where my usb was. now, i need to find out which one of my 4 usb ports is the one with the usb in it. it's labeled 1-4, but there's no labels on my laptop
Old Jul 12, 2005 | 08:01 PM
TobyZ28's Avatar
First off, I'm not aware of a USB connction to the OBD 1 comps. you need a serial cable from AKM that connects to the serial port on the back of the laptop.
As for USB connections, it sounds like your a bit confused. If you have 4 USB ports they ALL should work for whatever you plug in to them.
Old Jul 13, 2005 | 12:48 PM
blackztpi's Avatar
well, it is a usb from akm for obd1
Old Jul 13, 2005 | 01:12 PM
Alvin@pcmforless.com's Avatar
Your wrong there..
Maybe AKM will take there cable back and you can try one from moates.net. I have both serial and USB and the USB moates.net cable works flawlessly with Win 95+ software and OBD1
Old Jul 15, 2005 | 01:49 PM
TobyZ28's Avatar
I take that back then
"I'm now aware of a USB connction to the OBD 1 comps.
Old Jul 15, 2005 | 06:42 PM
jchevy's Avatar
I have the USB cable from AKM and it works great. It doesnt matter which port you plug the cable into. My computer has 2 ports, but i can choose 1-5 or something. I will have my directions at home, but i just followed his steps and works good for me.
Seems like you tell it to default to com port 4, and then when you open up what ever logger/programmer you are using, tell it also to use com port 4. Thats just what i kind of remeber.
It doesnt matter which port i actually plug into, they both work.
Old Jul 16, 2005 | 07:48 AM
weazel28's Avatar
Plug your cable into your laptop,windows should recognize new hardware.Insert CD ROM you got with cable,install drivers.To find out where your cable was installed go to control panel,then to system,then to hardware devices,then look at ports (com and lpt)look at com ports there. cable must be plugged in for com port to exsist. this is from directions that came with my cable,got it from akm electronics...
Old Jul 17, 2005 | 04:35 PM
MyGreenBabyZ's Avatar
i had this problem when i built my cable. I use the serial connection for the cable but my new dell laptop dosent have a serial port so i bought a usb to serial adapter and it still wouldnt work so i ended up having to buy a pcmcia card that adds a serial connection to the laptop. after doing that i tune my 94 flawlessly.
good luck!
Old Jul 17, 2005 | 06:54 PM
jchevy's Avatar
good luck!
He bought a cable specifically for the USB port, so he doenst need to worry about any adapters or pcmcia cards.
G-BODYT56
Jan 14, 2022 11:14 PM
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
marlar98
Sep 19, 2015 07:53 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
