monoblade and idle issue
Old Nov 23, 2009 | 09:49 AM
jasonisdn's Avatar
Has anyone got the monoblade to have a good idle? i did a search and came up with them for sale and wanted but not any tuning info.
My IAC counts will not stay in a workable area. they either 0 out or max out with only a 1/8th of a turn and waiting on it to settle down. the tps is at .65 to .69 and 0 %. I was wondering if the drill bit needed to pay a visit to the blade. Since when you turn the set screw you are opening that much surface area that the IAC can't counter it, in either direction.
See i am using a TH400 and when you put it in gear it likes to die unless the idle is around 1200 or so. So if i can get the IAC to function the way it should, it might help with that issue and i can drop the idle some. I hope.
Unless someone has figured out how to take a car that was a manual that went to a TH400 and make it know when it goes into gear. I am in over my head just a wee bit lol.
Dark Zeiro
Mar 11, 2015 07:15 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Gtpguy
Jan 26, 2015 04:50 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
