May have fried PCM...
Old Jun 25, 2004 | 12:40 PM
13sectransam's Avatar
I was just outside putting in a new program for my car. But before I did, i went to save the current program that was in the car and it was interrupted while downloading it. I would think that this wouldn't hurt the car as it really isn't taking anything away from it, just copying the information. But I tried to start the car after it was interrupted and nothing happens, the car will turn over but won't even think of firing. I just unplugged the battery in the car so that it would go back to factory spec. and hopefully everything will be alright. Does anyone know if it can do any harm if interrupted while saving the current program though?
Old Jun 25, 2004 | 12:54 PM
LT4ultraZ's Avatar
It will not hurt the PCM during downlaod, that is how i tested my laptop to make sure it would work and it took a couple of tryes.
Old Jun 25, 2004 | 02:11 PM
djw's Avatar
djw
Reading the pcm will not hurt it. It may cause it to "crash", if this happens you will need to pull the negative battery cable or the fuse for the pcm to reset the pcm.
madwolf's Avatar
No harm done during a read. It should fire right up after the battery disconnection.
Old Jun 25, 2004 | 02:32 PM
phew! she started right up after I unplugged the battery for a bit.. I was getting worried for a bit, I have a cruise to go to tonight. Thanks for the heads up though!
95_lt1_z28
Aug 30, 2015 06:17 PM
NewsBot
Aug 21, 2015 09:40 AM
NewsBot
Jul 3, 2015 02:10 PM
NewsBot
May 15, 2015 09:30 AM
NewsBot
May 15, 2015 08:10 AM
