MAF Calibration Excel Spreadsheet
Old Aug 9, 2008 | 07:06 PM
95Blackhawk's Avatar
Hey all,
A few folks have asked for this to tune the LT1 PCM MAF. I am glad to share it but I have not given a lot of instructions. Give it a bit of time to sink in and ask questions along the way.
Further, if you have ideas to improve it, I would really appreciate it.
Shoot me an email if you want it: irentat@***.net
Ben
Old Aug 11, 2008 | 03:51 PM
bobdec's Avatar
Ben, started playing with the sheet, I'll let you know how it works out. You are using the LT BLM's in the data sheets. What I noticed is the PCM takes a while to update them (average in the new settings) after changes. Should I assume the PCM should be reset after each change to make sure the old historical BLM data is cleared and the readings reflect only the latest change. Also guess I need to disable WOT (PE) to get any BLM readings for MAS above 98 GM/SEC, been reading your WOT tuning posts.
Old Aug 11, 2008 | 07:16 PM
You are correct on both counts.
On the BLM's, I massaged the data by throwing out the first few seconds of data in a particular cell because I knew the computer had not had a chance to modify yet.
I hope you can be another set of eyes looking at this stuff. I am the only one that has done this and, believe me, I don't know enough to be thorough on this.
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
