M6 or a4 tune?
Old Oct 29, 2008 | 03:36 PM
Prorac1's Avatar
M6 or a4 tune?
I did a tunercat tune a few years back, but cant remember if it was for the a4 or M6. Ive had both trannys in the car and dont know which one this tune was for. Is there anyway to tell by looking at the tune. Thanks Eric L
Old Oct 29, 2008 | 04:09 PM
seawolf06's Avatar
I thought they were the same and the M6 car will just ignore the tranny tables.
Old Oct 29, 2008 | 04:14 PM
Prorac1's Avatar
Maybe, but what tells it to do the skip shift and reverse lockout sol?
Old Oct 29, 2008 | 04:18 PM
seawolf06's Avatar
I didn't think those are controlled by the pcm.
Old Oct 29, 2008 | 04:25 PM
Prorac1's Avatar
Well they dont control them selves, lol.
Old Oct 29, 2008 | 06:04 PM
Kevin Blown 95 TA's Avatar
Skip shift is controlled by the PCM and there is a switch to turn it off in the tune as well as some parameters affecting when it is activated. Reverse lockout is also controlled by the PCM but I haven't seen an adjustment for the speed threshold or a switch to turn it off. You can always manipulate the solenoids however you want like if you want to shift into reverse while going 50mph or something.
Old Oct 29, 2008 | 07:58 PM
Prorac1's Avatar
so are the tunes for an a4 and an m6 the same?
Old Oct 29, 2008 | 08:28 PM
rngilliland's Avatar
A4 and M6 tunes are not the same. Check the speedometer calibration in the tools menu. If the pulses per driveshaft rev is 17 it is an m6 if it is 40 it is for an auto. You can also check the same thing in the constants table.
Old Oct 30, 2008 | 07:52 AM
seawolf06's Avatar
Oops, sorry bro.
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
