LT1 edit question
Old Oct 14, 2002 | 08:14 PM
TMDZ28's Avatar
Smile LT1 edit question
can i turn the fans earlier with this tuner?
Old Oct 14, 2002 | 09:59 PM
bigtwink's Avatar
Earlier, later, when-ever..... You can do it all with it.
Old Oct 15, 2002 | 06:44 PM
TMDZ28's Avatar
Smile
where can i buy this LT1 edit program?? do i need a good laptop for this program?? i really want to know....thanks
Old Oct 15, 2002 | 06:54 PM
DOOM Master's Avatar
You'd be better off getting Tunercat. It's much cheaper, just as easy to use, and it isn't VIN locked. Meaning you can use it on any number of OBD1 PCMs you want. If you have OBDII, then you can't use Tunercat yet. Go to www.tunercat.com to get all the stuff you need. It has a trial of 30 days, then you need to buy it but it's only about $100 for the program and EE definition file. And you need a cable, which is about $100. Go to http://www.akmcables.com/ to get the cable. Or, you can spend 2-3 times as much for the same program that doesn't do as much (LT1Edit).
Old Oct 15, 2002 | 11:07 PM
95Blackhawk's Avatar
Ditto what DOOM said.
Tunercat is the way to go.
Ben
Old Oct 16, 2002 | 05:17 PM
TMDZ28's Avatar
do i need a good laptop?? or just some crappy and slow one??
Old Oct 16, 2002 | 05:37 PM
A crappy one will do. Just make sure it doesn't have any booting problems or errors. Otherwise, you might end up in the middle of a programming frying the PCM. Which is annoying, because then you need to either reprogram the flash chip (which requires desoldering and reflashing the chip) or getting a new PCM and reprogramming it. Happened to me, thanks to my crappy laptop. I'm fixing it, however. It's an old 120 Mhz Pentium, certainly nothing fancy.
Old Oct 21, 2002 | 12:15 AM
TMDZ28's Avatar
i visited www.tunercat.com and i didnt know which one to download, any guideline??
Old Oct 21, 2002 | 05:27 AM
Chuck Everly's Avatar
You need the program called Tuner found here.
http://www.tunercat.com/software/tuner/tnr_setup.zip
You will also need a ECM definition file. They can be found here. http://www.tunercat.com/tnr_desc/do_tc.html
You will need to email TunerCat to get the correct ECM definition file sent to you.
oldschool
Feb 9, 2016 09:21 PM
rockync7
Jan 1, 2015 05:10 AM
Bando
Aug 2, 2002 02:18 PM
Chrisdude
Jul 24, 2002 02:25 PM
