lt1 Edit!!!
Old Nov 13, 2003 | 09:02 PM
mr_camaro96z28's Avatar
lt1 Edit!!!
Hey i just got my new lt edit in the mail and was wondering if anybody has any first time improvements. My mods are listed in the signature just wondering if there is anything somebody knows will help.
Thanks in advance any and all info is helpful.
Old Nov 14, 2003 | 06:14 AM
doodad's Avatar
Kind of hard without the air/fuel on a dyno run. Have you already programmed for the gears?
Old Nov 14, 2003 | 11:36 AM
Bodenham's Avatar
dropping exhaust backpressure may cause you some low speed high gear "Check engine" codes. May want to disable the egr codes to eliminate the annoyance. I had problems with 6th gear and 60mph throwing a code, edited out.
Old Nov 14, 2003 | 01:40 PM
Camaro_SS/R's Avatar
Yeah, with a dyno table you can fine tune the PE table to get the A/F at WOT tighter and may yield some hp. Also with some knock data you may be able to tune your timing some.
without those data,
You can program your fan to come on earlier couple with a colder thermostat to help your car run cooler. But remember way to cold may not be good. I will try to keep your temp around 185-190, no lower than 180.
You can also increase your rev limit as well. Maybe change your idle rpm if you want to. Turn off your cat back 02 check and light if you have off-road piping.
--Hugh
Old Nov 18, 2003 | 07:20 PM
Thanks for the info i changed for the gears without problems and in a couple of days i plan on changing the fan and maybe playing with the idle a little.
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
Bando
Aug 2, 2002 02:18 PM
