Low fan speed nearly never stop...
Since i ve installed a FTRA with my lid setup my car is running a little warmer than before.Specially in traffic.I knew it will do this but since a lot of member (ltx and of course lsx)run it, it didnt bother me.
But now my low speed fan doesnt seems to ever stop...I mean in traffic they never stop.If i let the car run at idle in my driveway with the hood open,the fan will stop once in a while. And by the way my car doesnt overheat at all.
I thought i had a alternator problem because i could see some voltage drop on my cluster gauge but its only cause because the low fan is always running.
Basic info:
-I got a 160 degree thermostat
-The low fan speed is set to start @ : 180 degree
-The high fan speed is set to start @: 185 degree
-The low fan speed is set to stop @: 177 degree
-The low fan speed is set to stop @ 182 degree
I wanted to try to make the high speed fan come on at 35mph(fan treshold high speed) to help while im running at a constant speed but it doesnt help when im sitting at a red light.
On my log with datamaster i can see that my low fan are coming on right at 180 degree and my high one at 185 degree.I never saw higher degree than 187.
So i would need some advice here.
-What can i do to make them stop ?
-Do i need to change some data in my tune (fan start degree and fan stop degree)?
-Does making my high speed fan run longer(more than 3 degree less)could help me?
Basic info:
Well that gives me an idea of what i should do and expect.
I ll try lower (185\190) then i ll go up(190\195) until im happy.
Did you use the fan treshold high speed or you ve leave it at zero.I was thinking that if i put it like at 35mph it could maybe cool down the engin better...But i ve never used this feature.
With My 160* I have mine set at 195/205 more towards Rob's settings, and also have not messed with the speed setting. My fans almost never come on in 80-90* weather except after prolonged stops. It runs along at about 185 using the air dam flow and never goes above 200 when stopped in traffic that 15* difference between 185 and 200 gives a good buffer so you can stop at a light or whatever for a minute or two w/o the fan kicking on constantly. Remember a T-Stat starts opening at the published temp and a rule of thumb is to give it 15* to fully open, so depending on physical characteristics your 160* it may or may not be fully opened at 185*. The temp when running under air dam control (no a/c or fans on) will let you know approximately how your T-Stat is working. . Let us know how you make out.!!
Well thank you both, i ve tried some setting today and made a lot of logs with datamaster.
I ve ended up with 200\210 with a 35mph treshold.
In normal city driving(stop and go) i saw a average between 185\190 degree.It would go higher in traffic but never pass the 200 mark.On highway i would get low 170degree temp.
The treshold is only if i hit 200 degree.The high speed one would help when i get to steady 35mph driving.
ChrisFrez
Nov 30, 2014 08:41 AM
Jul 4, 2005 05:00 PM
