just bought tunercat and a laptop..should I buy a USB or serial cable?
Old Jan 9, 2009 | 04:27 PM
drptop70ss's Avatar
Just bought tunercat and an older laptop that has both serial and USB ports on it. Anyone have any issues with the AKM USB cable? If the USB cables have issues I will go with a serial cable, but I figure for future use I may want to stick with USB. Any reason to go one way or the other?
Old Jan 9, 2009 | 09:29 PM
dookie454's Avatar
Serial always works
USB does not always work
Serial is a core process
USB+Serial is ready for failure at any point since it's Serial with a bunch of USB garbage on top of it.
If you have a serial port, use it.
If you have no serial port, you try a USB serial adapter.
Old Jan 9, 2009 | 11:27 PM
WS6T3RROR's Avatar
If you do get a usb cable I recommend the one from moates.net. Mine has been through an absolute ton of usage and has not cause me a problem yet.
Old Jan 23, 2009 | 12:27 PM
aknovaman's Avatar
USB cables need to have the FTDI chip within them. USB cables on the market are not simply usb adapters with serial circuits inside one box. DO NOT use a USB adapter with a PL2303 hhip in it. It uses different communication protocol and may interupt the comm process and fry your PCM chips.
Old Jan 23, 2009 | 08:05 PM
drptop70ss's Avatar
thanks, I ended up buying a serial cable.
Parts Wanted
Mar 17, 2015 11:24 PM
95chwagon
Feb 28, 2015 12:02 PM
grabbem88
Feb 10, 2015 06:20 PM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
