idle help
Re: idle help
What do you feel you would gain by wasting fuel in closed loop? Its not going to produce any power. When you apply the throttle to produce power, the PCM shifts to power enrichment (PE) mode, and sets a much richer target A/F ratio, that will make more power and torque. Unfortunately, the stock programming typically produces a target A/F ratio of 11.7:1, which it too rich. Reprogramming the PE tables to lean it out to something in the range of 12.5:1 to 13.0:1 will gain you anywhere from 10-15HP.
Re: idle help
Here's something you can use along with, or instead of, changing MAF Calibration or VE tables for idle AFR tweaking.. Can be used for intake systems that flow differently than stock at idle or in the lower AFGS conditions. You can play with the " Individual Cylinder Fuel Trim Multiplier" table. Adding or subtracting a percentage to the values alters the fueling calculations. EG: if your 3% rich at BLM cell 16 then multiply the 'At Idle column' by .97 to reduce fueling 3%. Conversely if you are lean to add fuel multiply by 1.03. The 'Off Idle' column in the table is used for low throttle conditions it cuts in at TPS>0% and cuts out with a constant table setting " Ind. Cyl Fuel Trim Disable TPS%" stock cutoff is TPS=14.8%. I used this and calibrating my MAF tables. Seemed after the cam and 1.6 RR's my idle and low end went towards the rich side and my high end went towards the lean side.
Re: idle help
Ray, TunerCat 'Tuner' program has one table with a column for each setting (idle & off idle) plus a constant setting for the TPS% disable value. Look under fueling sub section for tables and constants. TunerPro RT has a separate table for each setting and I could not find the TPS% disable constant or Scalar as TunerPro calls them. I do not know about Lt1 Edit..
autoxr166
Sep 25, 2015 04:21 PM
