IAC Park Position Vs. Coolant Temperature
Old Jun 23, 2004 | 08:41 AM
944v8inDFW's Avatar
Somewhat new to programming my own. Actually paid PCM's for a good profile, now tweaking in a few little things. Below you see my IAC valuse vs. Temp. Should the hotter ones be a bit higher? The reason I ask is at hot idle from time to time the engine "hunts" idle. Maybe dropping to 500 rpm then back or dies. I have big cam, big throttle body ect. If someone could 'splane what that table does at the very least. That may be a good start.
Deg C Steps
-40 115
-28 106
-16 81
-4 69
8 62
20 55
32 49
44 39
56 30
68 21
80 14
92 7
104 7
116 7
Thanks As always
Old Jun 24, 2004 | 10:52 PM
bunker's Avatar
I belive thats the position your car takes the IAC to when the engine is not running & the key is in ignition position, the one your thinking of is IAC vs. MPH counts, increase those at low speeds & it will have less tendancy to hunt, at 0 mph set it from 3 to say 7 & it should fix it up, another thing to do is to set the idle screw a bit more open, but like I said, the park position is the position your IAC takes when starting the car.
blac94Z
Feb 15, 2021 09:43 PM
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
