I want to tune my 95 camaro
Any shops around ohio that anyone knows of that would tune it or is it easier to just buy the cable and tune it my self
I have a bigger cam diff. heads and a gov. that needs to go..
Thanks for any help you give me.
where do you reccomend i get my cable from i need a usb connection thats all i have for my laptop...
I seen two diff places one the cable is a lot more and one the cable is less
the one is aldl
the other is akm cables...
if there is any other ones that anyone reccomends for better pricing or easier access let me know
thanks.
the one is aldl
thanks.
Final03:
I went to Tunertools.com ( http://tunertools.com/ALDL_Cables.asp ) and bought "Product ID: OBD2-aldlobd2u ALDL Cable w/OBD2, USB Version"
They have an 800 number so you can call to be sure of which cable to get.
I'm using this on an ACER running under Vista.
Good Luck ...
Good Luck ...
atleast i found out that i do have a 16 pin connection...
The bad part about it is i was going to buy one cable and tune mine and my freinds but his is a 94 with a 12 pin connection lol
so guess thats outta the question...
Final03:
Try this link to a conversion for 12 pin cables to 16 pin 1995 ...
http://shbox.com/1/xraycable.jpg
It's courtesy of Camaro Z28 moderator Shoebox. You might want to pm him to be sure it would allow you to use one (12 pin) cable for both cars.
http://www.obd2allinone.com/sc/detai...item=aldlobd2u
Finally ordered my cable and this is the one i ened up ordering...
Now i just gotta figure out which software to use... Prob try free scan first of all.. Because right now the only tune i want to really do becuase i don't know much about tuning is change the top speed limiter to 255...
You can tune out the top speed governor, plus you can save your stock tune in case you ever need to go back to it. You can tune out any OBD codes, such as AIR, EGR, etc.
For true tuning, you really need to invest in a wideband.
But in the mean time, you need to get lots of practice logging and charting data so you are familiar with the important parameters.
