I just bought new computer, downloaded prog,but
Old Aug 16, 2002 | 01:30 PM
  #16
dayusmc's Avatar
From: Stationed at Camp Lejeune, N.C. (But Going Home SOON!)- From New Jersey
Post
Me too! I thought that it had a diffent vin than the program (.bin) you were trying to put in it. There is another way too have the ecm flashed besides the dealer, but that requires sending it to PCMFORLESS or TunerCat. Dealer would be easer. If you do get it flashed at the dealer- Post how much they Robbed(Charged)You. That way everyone can have an idea if they have to have it done. We will also know if soom dealers are charging way to much.
KYLE-SERGEANT USMC
97 Trans Am with minor mods.
EMAIL: dayusmc@marinecorps.com
Old Aug 16, 2002 | 01:48 PM
  #17
dayusmc's Avatar
Post
Just thought of this, but I have the Vin change program(as probably a lot of other people) That may also work. But if the moderator is going to fix it for than you don't need it. The VIN change is a real time program. I have never used it because I am running Windows 2000 and don't have a true DOS prompt. But as far as I know you just hook it up and change the vin info. Well make sure that you post what the problem was, that way when it happens to someone else we will be able to better help them.
KYLE-SERGEANT USMC
Old Aug 16, 2002 | 04:05 PM
  #18
Dr.Mudge's Avatar
Post
Tunercat does not complain at all about mismatched VIN numbers, this is only part of the licensing issue behind LT1 Edit.
Since the VIN cannot be overwritten by eithe product, the only use of VINchange is for editing it in an actual LT1 Edit file for the purposes of actually loading the file into LT1 Edit where the VIN in the file does not match the licensed VIN.
Sounds like he is taken care of though.
Old Aug 16, 2002 | 05:10 PM
  #19
gb95zconv's Avatar
Post
Guys Im telling you if its a new pcm (remaned) and has no file in it your not going to be able to put one in it with TC. Its kind of like a computor with a new haddrive....it has to be formated before you can use your software....Andrew can take care of this for you. The VIN makes no difference .
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Old Aug 16, 2002 | 11:19 PM
  #20
Dr.Mudge's Avatar
Post
If that were the case however, then Tunercat would have never completed the flash, so I'm a bit lost on that one.
Old Aug 18, 2002 | 03:07 PM
  #21
RCF925's Avatar
Post
I agree with Dr. Mudge, My old pcm was bad but I had downloaded all the settings with Tunercat onto my laptop. Bought new Computer that autoparts told me it would need to be flashed, Uploaded all the old settings, Runs fine.
ChrisFrez
Mar 22, 2015 07:00 PM
ChrisFrez
Mar 8, 2015 01:22 PM
ChrisFrez
Mar 1, 2015 01:33 PM
95chwagon
Feb 28, 2015 12:02 PM
99TransAmWS6
Jul 26, 2002 03:18 PM
