hypertech programming question
Old Mar 19, 2005 | 05:18 PM
fearnside5's Avatar
What rpm do you set for idle? (95 Z A4) Do you set it for in gear rpm or in park rpm?
Old Mar 20, 2005 | 09:23 PM
2cub49's Avatar
Re: hypertech programming question
You can't set the idle with hypertech.
LT-1 Edit or Tunercat is needed for that.
Being a 94 obd1 the software isn't that expensive.
You can also copy your hypertech program before returning your PCM to stock.
Then you could sell your hypertech for 150.00 or so and be able to do much more as well as having Ion or Brian sending you professional tunes you can flash your PCM with if you add more mods.
Injuneer
Dec 15, 2014 09:36 AM
thenewkid
Nov 27, 2014 09:41 AM
lbrowne
Nov 13, 2011 04:25 PM
94z28jbw
Sep 8, 2002 03:22 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
