how to program for 26 injectors
Old Sep 21, 2002 | 08:54 PM
TSearsJr's Avatar
I installed #26 injectors into my 95 camaro. I am using tunercat and would like to know how to adust my programing for these injectors.
Thanks Terry
Old Sep 22, 2002 | 07:30 PM
Hal Fisher's Avatar
Its right in the second table (ECM Constants). There is a setting for injectors size.
Hal
Old Sep 22, 2002 | 07:43 PM
TSearsJr's Avatar
I had changed that table to 26lb but the car did not seem to run right. blms were showing 142/148. I moved the fuel pressure up to 42 vac line on 50 vac line off and set the constant to 24.5lb. the blms now at 130/132. I have not tried anything else yet.
Terry
Old Sep 23, 2002 | 04:19 PM
Ernest's Avatar
If you set it back to 24lbs does it then work correctly? If it does, those aren't 26lb injectors, or, they are rated differently. What are the exact specs of those 26lbers? You will notice that some injectors are rated at 39psi, some at 42,some at other strange ratings. If your BLMS are lower when you lower the injector size, it means it's trying to richen the fuel still, but not as hard as it was. Sounds like those are 24lb injectors.
-Ernest
Old Sep 23, 2002 | 06:06 PM
TSearsJr's Avatar
After I Bought the injectors (Stock GM #26) I read on these post that they are for the LS1's. They run a higher fuel pressure than the LT1's. I may have to ditch these if I can not figure them out maybe for SVO 24s or SVO 30s
Thanks Terry
Old Sep 23, 2002 | 06:44 PM
Ernest's Avatar
That's what I figured you were going to say. I'm estimating here, but an LS1 26lb injector is rated at something like 42.5 psi, while an svo is rated at 39psi. So a 26lb 42.5 psi rate injector is really a 24lb injector, because the lower rating is what most people refernce against. Yeah, sell those, and get some 30lbers somewhere else.
...and of course, check the psi rating they use..
-Ernest
RUENUF
Mar 13, 2016 03:37 PM
4586
Aug 22, 2015 01:09 AM
Slayer
Aug 17, 2015 03:55 PM
whitehooptie
Aug 10, 2015 07:02 AM
Anon
Jul 23, 2015 12:18 PM
