How to adjust part throttle and WOT fuel on TC??
Old Jun 12, 2004 | 11:23 PM
Ryan94ZA4's Avatar
I have usually used the mass air to get the fuel where it needs to be. I once tried the modify air/fuel but it didn't seem to do anything.
Anyone care to share their experiences on tuning for part and WOT? I want to make part throttle as efficient as possible to maintain reasonable fuel economy while adjusting WOT for max power.
Thanks,
RYan
Old Jun 13, 2004 | 12:38 AM
roadtrip120's Avatar
I don't mess with MAF talbes but everyones different. To adjust fuel use
% change air/fuel ratio vs cool temp at WOT
and
% change air / fuel ratio vs rpm at WOT
not sure on part throttle sorry
Old Jun 13, 2004 | 09:35 AM
Ryan94ZA4's Avatar
OK, when using the % to change AFR at WOT, does increasing the number richen and decreasing the number lean it out or is it just like an air fuel ratio where a lower number is richer and a higher number is leaner?
Ryan
Old Jun 14, 2004 | 02:38 AM
you have to use a formula to calculate the target AFR
vea Andrew
=(1-(# in temp table)+(# in the rpm table))/100)*14.7
the computer uses both tables to figure the target AFR
But to answer your question the higher the number the richer it gets.
And vise versa
HectorM52
Jul 30, 2017 11:46 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
