HELP! My laptop died while programming...:(
Old May 19, 2004 | 08:30 PM
RamAir95TA's Avatar
What should I do? It was 85% completed, and the laptop crapped out. I know the PCM is dead, but what are my options?
Can I get any PCM from a 94 or 95 whether its an A4 or M6? Can mine be repaired?
I just finished my cam install, and that was the last step. Now I can't start the car. Any help?
Old May 19, 2004 | 11:20 PM
flyinZ's Avatar
would, trying to reload "that" program, again, work?(just a thought)
Old May 20, 2004 | 02:25 PM
RamAir95TA's Avatar
I tried cranking it over after the laptop died, and I'm getting no spark. Just before, there was PLENTY of spark, so I am pretty sure that the PCM is toast.
Old May 20, 2004 | 04:33 PM
LukeZ28's Avatar
I just started messing with tunercat and i had mine freeze during a read, which is not programing. I was worried at first, the pcm didnt do $hi!. After i reset the pcm with a battery reset it was all good. Try a reset and flash again. cross fingers
Old May 20, 2004 | 10:33 PM
RamAir95TA's Avatar
It screwed up during the read process, and the same thing happened you described. I reset the PCM, and all was fine.
Then went to program, and boom...
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Bxlt1
Sep 29, 2015 03:18 PM
KYWes
Sep 26, 2015 08:49 AM
