help ????????????
Old Apr 27, 2011 | 10:06 AM
DTRJAR's Avatar
Question help ????????????
what is the best tuning program and logger,, all so what program can i get to read the codes for diagnostics thanks and i have my cable trying to get my car tuned and all
Old Apr 27, 2011 | 12:22 PM
Mystery Bird's Avatar
Re: help ????????????
For 95 I think the best is Tunercat. For logging and diagnostics Freescan or TTS Datamaster. Tunercats now sells bundles to you can get everything you need.
Old Apr 27, 2011 | 01:08 PM
DTRJAR's Avatar
can someone get me the add to download freescan i cant find the one for obd1
Old Apr 27, 2011 | 01:40 PM
DTRJAR's Avatar
the setup wont work on my pc WTF i have downloaded it 5 times help
Old Apr 28, 2011 | 10:38 AM
bobdec's Avatar
Some things to check that have caused problems with Freescan.. ...Did you download it from here http://www.andywhittaker.com/ECU/Fre...0/Default.aspx . What type of failure are you seeing, what is your laptop Software OS , do you have a USB or serial OBD1 cable with an OBD2 connector for your '95 setup, if it's serial cable using a USB adapter then is the adapter supported, is the correct cable driver loaded , is the COM port set correctly and have you selected the "Force Data" - Interact radial button on the main FreeScan menu. ?
