help ????????????
Re: help ????????????
Some things to check that have caused problems with Freescan.. ...Did you download it from here http://www.andywhittaker.com/ECU/Fre...0/Default.aspx . What type of failure are you seeing, what is your laptop Software OS , do you have a USB or serial OBD1 cable with an OBD2 connector for your '95 setup, if it's serial cable using a USB adapter then is the adapter supported, is the correct cable driver loaded , is the COM port set correctly and have you selected the "Force Data" - Interact radial button on the main FreeScan menu. ?
