gaining power from pcm tuning
Old May 9, 2007 | 05:47 PM
Spudz's Avatar
I know theres benefits of computer tuning, but I dont see how it makes you gain HP and TQ. Anyone care to explain?
Old May 9, 2007 | 06:19 PM
aifilaw's Avatar
fine tuning an engine makes the most out of what is there, you are *hopefully* increasing efficiency by setting the timing, and A/F ratio throughout the powerband, while the stock tuning were simply ballpark guesses by the manufacturer...close, but not perfect.
Old May 9, 2007 | 06:46 PM
VinceTrifecta's Avatar
Stock LT1 owners can expect 15, sometimes as much as 20 HP gain from custom programming. This is either because the factory wanted to make sure people like me had a job :-) or because they were conservative in their timing curves and fuel mixture. Stock engines run too rich at WOT, and can usually benefit from more spark advance, especially in the upper RPM range.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Bignasty85
Mar 3, 2015 04:05 PM
nikolt1
Feb 27, 2015 09:10 PM
turbo_Z
Aug 19, 2002 10:50 PM
