Flshread.exe error #5 address 9039? Anybody know what this is?
Old May 1, 2003 | 07:10 AM
Asskikr's Avatar
Unhappy Flshread.exe error #5 address 9039? Anybody know what this is?
HI Guys,
I am getting the following error when trying to read my pcm, it pops up during the establishing communications part. I tried it from my desktop and my laptop, same message, I am using version 3.10 Andybody know what this is.
Old May 3, 2003 | 12:34 PM
tjwong's Avatar
First off, are you using TunerCat or LT1 Edit? If you are using TC then what version are you using. The latest version of TC is now at 2.0, if you are using just the TunerCat flash program then that is at 2.04b.
Howevever you should use the latest TunerCat program and in the tools menu, perform your read and program functions from there.
Or if you prefer to use the older method of using their windows flash utility. Perform this check:
Start up the flash utility program. Hit keys "ctrl, T" then you will see that a test menu appear on the menu bar. Click on "test" then check the box "debug to file" that saves all comm errors to a text file. Then email that file to:
TC@tunercat.com
Explain the problem to TC, he will email a fast response to your problem
Old May 3, 2003 | 08:40 PM
Asskikr's Avatar
tHANKS MAN, bUT i GOT THE LATEST VERSION AND GOT IT TO WORK!
Old May 3, 2003 | 09:02 PM
Abdullah's Avatar
same problem here when i try to use flashprog.exe or flashread.exe version 3.11 and it is an older version compared to the newest from TunerCats. so shall i do the same debug the file i mean? isn't there any other method?
Old May 4, 2003 | 01:48 AM
Dr.Mudge's Avatar
If the newer version fixed his, then request the newer version from Tunercat, updates are FREE with Tunercat.
If you continue to have problems, my question would be did you have someone tune your computer professionally?
Old May 4, 2003 | 02:56 AM
tjwong's Avatar
Abdullah, just download the latest version of the TunerCat Tuner software, that will enable you to read and program direct from the Tuner Software without using the Flash utility.
TunerCat is up to version 2.0 now, there was a bug in version 1.98 that had some problems with the checksum when using the EE definition file.
Nayr
Mar 3, 2023 08:34 PM
marlar98
Sep 19, 2015 07:53 AM
Sep 18, 2015 03:46 PM
whitehooptie
Aug 10, 2015 07:02 AM
asilomar244
Jul 12, 2015 05:53 AM
