Fan Hystersis
Old Feb 27, 2004 | 09:54 PM
Prorac1's Avatar
Fan Hystersis and PE tables
How do i adjust the fan shut off temp with the fan hysteris. And what is the Pe table, and what does it adjust. Thanks Prorac1.
Old Feb 28, 2004 | 12:15 AM
97Z-M6's Avatar
fan hysteria is the temp the fans come -3 degrees. so if you have the fans come on at 80c when the temp gets to 77c the fans turn off.
pe mode is
%change to fuel/air ratio Vs cool.temp wot
" rpm at wot
the formula is in the help menu on tuner cat. under tables and look for the to tables above. and in one of these table it has the formula
it is used everytime you punch it. it called PE mode (power enrichment mode. it is a target A/Fratio the pcm tiys to hit when you go wide open throttle. but when you go wot if the last blm is above 128 the pcm add that to the preprogramed A/F ratio.
so you need to get the blms correct to accuratlly get the pcm to try and target what you want.
__________________
Old Feb 28, 2004 | 02:29 AM
Prorac1's Avatar
WOW, thanks for the info. What should my blm's be? Right now my short terms hover around 108-114. Thanks, Prorac1
Old Feb 28, 2004 | 02:58 PM
97Z-M6's Avatar
i like mine to stay around 125 but ideal lt blms is 128. dont worry about st blms they are only used once and thrown away the LT blms are use longtern.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
Pwilson59
Sep 3, 2015 08:47 PM
4586
Aug 24, 2015 11:04 PM
