early OBD2 no scan, error
Old Apr 22, 2003 | 07:58 AM
SSC's Avatar
SSC
Hi guys.
Ive had problems with scanning 95 obd2 systems and wonder if anyone has any suggestions? Its happended on S10's and now since my brother bought a 95 camaro I need to know whats going on with these systems. I replaced my old generic obd2 scanner for a less generic global scanner but the system still will not interface "data link error". All ecm fuses check out no broken pins nothing obvious. Any help would be great.
SSC
Old Apr 22, 2003 | 09:03 AM
madwolf's Avatar
95 LT1 is not an OBDII. It has an OBDII connector, but the PCM is still an OBDI. You need an OBDI scanner with an OBDII connector.
Old Apr 23, 2003 | 12:03 AM
SSC's Avatar
SSC
Thanks for the info. The car is not a Lt1 just a 3.4 but The system still should be OBDI then right?
Where can I get an ODBII connector for OBDI sys?
Thanks.
SSC
Old Apr 23, 2003 | 09:36 AM
madwolf's Avatar
That's a good question. Honestly, I don't know, but you might want to check with Andrew Mattei at www.akmcables.com. I'm sure he'll have something for you.
Nayr
Mar 3, 2023 08:34 PM
KYWes
Sep 26, 2015 08:49 AM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
