Dyno tune - typically worth how much with my configuration?
Old May 19, 2008 | 09:20 PM
G. McDonald's Avatar
Hey,
You see the mods below. I had the tune done at PCMForless and after a bit of an idle problem that was remedied by adjusting the cruise control cable to work properly with the Summit58mm TB, it has been running quite well (though I have not had it to the track).
The question is, how much HP/TQ would you expect a good dyno tune might find for me, keeping in mind that I am in Toronto and have to remain emissions-legal? Anyone know a good tuner in the area?
Thanks for the input.
Old May 20, 2008 | 01:09 PM
blkchevyz's Avatar
depends on how far off the tune is. you could gain alot of none.
i'd just go get it dynoed with a wideband o2 and then see if you need it tuned.
Old May 20, 2008 | 05:36 PM
slomarao's Avatar
i would do it. You have a complete aftermarket top end. It should be worth it unless your tuner is amazing.
Old May 22, 2008 | 10:18 AM
95Blackhawk's Avatar
Yes you would gain most likely. Make sure and tune the WOT timing map also not just AFR.
HarleyZ28
Oct 5, 2015 06:23 AM
Stay Puft
Middle Atlantic
Apr 19, 2015 11:39 AM
Jlo
Feb 3, 2015 09:41 PM
chevysam
Jan 16, 2015 07:45 PM
SC97TA
Sep 15, 2002 01:10 AM
