DIY Wideband logging
Has anyone successfully built the DIY wideband o2 sensor (www.diy-wb.com) and logged the output along with other engine parameters? I'm toying with the novel idea of using the A/C pressure sensor harness as the wb02 signal line since Datamaster will log this signal and the PCM expects the 0 to 5v range needed for the diywb02. If anyone has done this or has any other input/suggestions, pleas post.
-Jay
94Z A4
Comp Cams 306, GTP Stage 3 heads, other stuff.
<A HREF="http://www.LT1tech.com" TARGET=_blank> www.LT1tech.com </A>
-Jay
94Z A4
Where else has this been discussed??? If the A/C pressure sensor does truly use a 0-5V range, then it should be no problem wiring a WB sensor to it. Let me know what you find out...
Jose
97 SS #1500 T-76 383
88 Supra Turbo CT-26/T04
87 Buick Grand National T-70
Jose
Yes it is a 0-5 mv signal with the 5 mv being provided by the pcm. It is on the same circuit as the TPS switch on my 93.
The only way I know is I melted that sensor on the race car (!AC) and it shorted out and also grounded the TPS sensor!
Perry
Perry
Sep 18, 2015 03:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
