deleting egr?
Old Jul 20, 2010 | 10:21 PM
brucer's Avatar
deleting egr?
egr enable,min rpm set at 6375
egr enable max rpm set at 0
i still get the ses light, do i need to uncheck the egr electrical failure 27 flag also?
Old Jul 21, 2010 | 09:06 AM
bobdec's Avatar
Assume you are a '94-'95 F-Body. The PCM expects to see +12 volts from ignition, through EGR solenoid back to the PCM when EGR is NOT commanded on, and 0 V when EGR commanded on. So if EGR solenoid, fuse, harness connector, etc are left intact then no need to remove the X for DTC 27. However if any of the circuit is physically opened or removed the +12v does not reach the PCM and you have to remove the X in the switch table to disable the DTC.
Old Jul 21, 2010 | 10:24 AM
brucer's Avatar
thanks bobdec..
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
tnmotown
Aug 10, 2015 11:52 PM
