DATAMASTER veiwed parameters
Old Apr 15, 2003 | 08:24 PM
SMOKNZ's Avatar
Can you change what Datamaster logs? I'd really like to see what the MAF output is at various RPM's so I can be able to tell what RPM I max it out at. Thanks
Bill
Old Apr 15, 2003 | 10:18 PM
Dan K's Avatar
You can view both maf grams/second and rpm.
Old Apr 16, 2003 | 06:03 AM
SMOKNZ's Avatar
I understand that i can veiw RPM. I know how to log and veiw it later with datamaster. I just don't know how to change the parameters that I can veiw. There are only so many spaces that you can use to veiw data and mine are all filled. How can i remove one that i don't really use and add the MAF? Do i need to go under the File menu and select import engine data? and then it will be available? Thanks for any help.
Bill
Old Apr 16, 2003 | 06:11 AM
SMOKNZ's Avatar
Nevermind, the MAF flow rate is labled in Datamaster as AFGS. Got it figured out.
Bill
Bails098
Aug 17, 2015 05:15 PM
Aug 7, 2015 01:26 PM
jdelaprida
Jul 4, 2015 03:02 AM
jdelaprida
Jun 27, 2015 08:30 PM
kandied91z
Sep 14, 2002 08:37 PM
