Corvette LT1 tune vs Camaro
I found a bin on Moates that states its a "Stock 94 Corvette tune". Would there be any benefit to loading this into my 94LT1? It has a higher extended spark advance and might have some other interesting things. I tried to do a search but didn't come up with anything. I'm running a 94LT1 with headers, full exhaust, and a different intake. All else is stock.
Did the 94 Corvette have any different hardware? I think they had the LT4 package that year. If someone could confirm that would be great.
Looking down the two bins, it seems like the corvette has more tranny line pressure, more spark advance everywhere, a higher knock attack rate. Basically the same with a little more added. Do you think it would be fine to add the corvettes tranny and spark tables into mine?
the Lt4 was 96 in vettes and 97 in f-bodies.
the vette will definately have a different tune,it has better ex.,better air intake the car is lighter in weight so the timing can be higher as far as the line PSI being higher it needs to shift firmer than the f-body off the showroom floor...
it would be better fotr you to spend 150.00 with a mail order tune than to guess at variables between to VERY different cars.
ChrisFrez
Dec 7, 2014 06:01 PM
