Converting PCM from M6-A4
Old Jun 9, 2005 | 01:10 AM
jchevy's Avatar
I am helping a friend with a conversion to an A4. I have LT1 edit and a PCM that is flashed for an M6. How do I change it to an A4 PCM.
Do I simply tell it it is an F-body with an A4 when it asks me to verify transmission? Is it that easy?? Its OBD1 BTW.
Old Jun 9, 2005 | 03:29 AM
bunker's Avatar
Re: Converting PCM from M6-A4
No you have to upload an A4 Tune, I haven't looked into this much, from when i tried simply doing what you said doesn't work, need an A4 flash and use Tuner Cat to upload it.
Old Jun 9, 2005 | 10:54 AM
sabre81's Avatar
get a stock a4 file from here. http://www.bfranker.badz28.com/LT1Edit/LT1files.htm
upload it to the car, done.
Old Jun 9, 2005 | 12:46 PM
jchevy's Avatar
Problem is the car isnt stock, i am gunna need to make tuning changes.
Can I read the A4 file into the car using tuner cat, and then read it out using my LT1 edit? Will that put my vin on it and allow me to make the changes i need?
Old Jun 9, 2005 | 01:35 PM
bunker's Avatar
No it will not.
Old Jun 9, 2005 | 05:14 PM
97Z-M6's Avatar
i dont hink you can load a a4 tune in a m6 pcm but you can the other way.
dont quote me on that though
dboone2172
May 16, 2015 07:45 PM
thenewkid
Apr 12, 2015 07:42 PM
ChrisFrez
Feb 15, 2015 07:49 AM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
