common VATS issue, please help technologically challenged
Old Jun 13, 2008 | 05:52 PM
SinisterFormula's Avatar
i kno this is over done, ive decided to program out vats due to inconsistant starting, via resistors and new pellet less key,
1. can i use the chipped key after fix?
2. do both wires goin in or which one?
3. soldier and tape, i know the correct ohm rate, 687? hope radioshacks right
4.if its on again off again w/o flashing, is this the correct fix?
help, gota work in 12 hours!!
Old Jun 14, 2008 | 06:13 AM
1 Yes
2 don't understand the question
3 solder for a permanent fix
4 security light should stay off
All the info you could want on this is on my Tech Page.
Old Jun 14, 2008 | 12:11 PM
i meant in the second question, do i put a resistor on both wires or do i cut just one, if its just one which is it?
chstitans42
May 1, 2015 01:03 PM
Lakebratt
Feb 5, 2015 07:55 PM
NewsBot
Jan 29, 2015 07:10 PM
Snoman73
Nov 17, 2014 07:22 PM
derty
Apr 22, 2011 01:14 PM
