Is this a change to make for a 58mm throttle body?
Old Feb 15, 2005 | 05:25 PM
Arctic_White_WS6's Avatar
I was thinking that a person would want to lower the values in the "% TPS postion for WOT vs RPM" table. This would compensate for the fact that a smaller % opening with a 58mm throttle body will supply the same amount of air as a larger opening on the stock TB. Therefore, if the numbers in the table are not adjusted down, a car will a 58mm throttle body will be under more load before going to PE mode.
It may not be desireable to stay in closed loop 14.7:1 operation at load levels larger than the stock setting.
Or, will the MAP threshold to enable WOT setting take care of this?
This really only makes a difference at part throttle. But, if you are seeing knock at throttle openings say, 10% less than where it trips to PE, it would be hard to tell whether that is timing related or a result of still running at 14.7:1.
Old Feb 15, 2005 | 07:24 PM
Jon A's Avatar
Re: Is this a change to make for a 58mm throttle body?
Yes. I did it.
HectorM52
Jul 30, 2017 11:46 AM
David Dorris
Jan 17, 2015 08:10 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
