Car wont start
the key is bad or the wires to the ign lock cyl broke off, this is very common, the easiest and cheapest fix is to just measure the resistance of the pellot in the key with a quality ohm meter then just make the same resistance/ resistor from radioshack and solder it to the 2 wires under the dash that normally go to the lock cylinder(they are in an orange wire covering)
