Can't create a good File with Tunerpro
Old Jul 6, 2007 | 06:58 PM
85DropTopTA's Avatar
Hi
I have successfully read and wrote a stock bin to my 94 A4 Trans Am GT. but when i make the simpelist changes to the bin it wont work in the car. the check engine light flashes very fast until I write the stock one back to the car. Then everything is normal.
I am using the EEb.xdf file. The EE mask shows 0 for cylinder volume so I figured since EEb shows 717.25 it would be the one for me.
anyone know what could be up with the file i created
Old Jul 6, 2007 | 08:47 PM
stereomandan's Avatar
Do you pull the PCM fuse, wait 10 seconds or so, and re-insert the fuse after you flash the PCM? Not sure if it will help, but some guys have problems with flashes unless they do this.
By the way I don't think there is a Trans Am GT, just the Firebird Trans Am.
Dan
Old Jul 6, 2007 | 10:10 PM
I tried pulling the battery for 5 min. I think that would have accomplished the same thing.
the Trans Am GT existed in the 94 Model year only. I didn't know if it made a difference but sometimes every detail helps.
Old Jul 8, 2007 | 10:52 AM
Well I found out i need the upload AA the the mask ID byte instead of EE. that should disable the checksum.
Anybody know how to do that?
NewsBot
Feb 6, 2015 05:00 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 21, 2015 06:10 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
