Can someone verify injector serial numbers?
I tried in the LT1 section and didn't get any responce. So I'd like to try in this forum ( moderators, please do not move this to the LT1 secton )
I have what are suppose to be 42lb Lucas injectors and cannot get the car to run ( with proper programming ). The car fire right up and idles perfectly fine, but as soon as I touch the throttle the car dies. using a 2-bar map sensor - 42lb injectors and a chip programmed for map+injectors.
I think that problem may be with the injectors. They are used and suppose to be Lucas 42s, but 3 have different numbers on them?
Serial numbers are
01D030B and D3181AA
Injectors are totally black ( my old 30lb injectors have a red stripe around them, these 42s have no markings. )
Can anyone tell what I have?
Could they be low Z instead of high Z or maybe smaller then 42 lbs?
Thanks John
Serial numbers are
01D030B and D3181AA
Thanks John
Re: Can someone verify injector serial numbers?
01D030B is a PN for a Delphi/Lucas 42lb injector.
Check out Racetronix... I think these might be similar to what you've got.
Originally Posted by Racetronix
D3181AA is not a 42# injector.
Thank you! Any idea what size it might be? Could it be a 36lb? The person had both sets for sale, maybe they got mixed?
Sorry to revive an old thread from the dead, but I just thought the Racetronix response was funny. I found this thread while searching for info about at set of "flowed, balanced, used Lucas 42.5# injectors" (purchased last year) that is going into an upcoming project of mine. The numbers stamped on mine are 621031 and D3181AA. Pretty quickly verified that they are indeed 42.5# Lucases...even on Racetronix's site. From:
http://www.racetronix.com/621031.html
Part Number 01D030B (Lucas old 5208009, Lucas New 621031, Delphi old D3181AA)
All tests run with n-Heptane @ 20oC (+/-1oC), 3.0 Bar (+/-0.01 Bar), 14VDC (+/-0.05VDC), saturated driver with RC cutoff
Static Flow Rate: 42.29 lb/hr (+/-4%)
Dynamic Flow @ 2.5ms PW @ 100Hz: 9.96 mg/pulse (+/-6%)
Coil Resistance: 15.9 Ohms (+/-0.35 Ohms) (This high-impedance injector will work with all factory ECM/PCM injector drivers)
Spray Pattern: Tri-Cone
Physical Dimensions: EV1 Body Type
Connector: Minitimer (Bosch EV1)
Factory fitted with Viton upper and lower o-rings.
Grease supplied to lubricate o-rings prior to installation.
