Can someone please take a look at my cars scan
my car has recently statred to to stumble and shutting off
just took these readings with an auto(xray) let me know
what you think. Any help is appreaicated I know noting about tuning.
mods in sig
Readings taken at idle
Desired idle 850
Engine rpm 850
Map sensor 1.76, 1.78, 1.78
Throttle sensor .58, .58, .58
Barometric pressure 4.88
Left o2 475, 862, 585 (range from 242-844)
Right o2 118, 79, 642 (range from 48-814)
Blk learn cell 16
Left block learn 134
Right block learn 138
Left integrator value 132, 132, 132
Right integrator 129, 129, 127
Spark advance 30, 28, 28
Knock retard 0
Loop status closed
Light cruising
Desired idle 800
Engine rpm 1225, 750, 875 (Car stumbling it went as low as 400)
Map sensor 1.48, 2.37, 2.11
Left o2 932, 26, 572
Right o2 924, 30, 651
Blk learn cell 5, 9, 5
Left blk learn 124, 129, 124 (range from 123-131)
Right blk learn 127, 128, 127 (as high as 137)
Spark Advance 31, 23, 24 (as high as 32)
Knock retard 0, 5, 4
Knock sensor 200, 200, 11
Vehicle speed 32
Loop status closed
mods in sig
Desired idle 850
Engine rpm 850
Blk learn cell 16
Knock retard 0
Loop status closed
Light cruising
Desired idle 800
Vehicle speed 32
Loop status closed
Re: Can someone please take a look at my cars scan
What gave you that software wise?, anyway i'm a noob granted but I can't tell anything from that. You need a log from datamaster or a similar app.
