Can someone HELP???
Old May 9, 2003 | 01:10 PM
Mr_Superman's Avatar
Exclamation Can someone HELP???
I want to order an AKM cable to do the pcm4less tuning...here is my problem...I originally had a 95 V6 3.4, and I replaced my 3.4 with a 94 LT1. The AKM cable plugs into the diagnostic port in the car and I was wondering if the cable will work and what year I will need to order the cable for. The wiring inside the car is still original from the 95 but the underhood wiring is all from the LT1, computer and all...Will it work what do I need to order??? HELP
Old May 9, 2003 | 06:41 PM
DOOM Master's Avatar
I don't know what the 3.4 came with for the ALDL port, but it's pretty easy to check. Look at the port and if it has the 16 pin port, you need the 95 OBD2-style cable for OBD1 PCMs. If you have the 12 pin OBD1 style ALDL port, you need the 94 OBD1 cable. Hope that helps.
