Cable Question
Old May 27, 2015 | 04:07 PM
MichiganSkip's Avatar
Cable Question
Guys, I used to post under s_willis for years here. But haven't posted in some time. I used to program my 95Z8's with a serial cable going thru a black box, from Andrew, then updated to the USB to Serial converted cable, still thru a black box. I see now that people offer cables that have the ALDL plug on one end, and a USB plug on the other.
Has the programming and datalogging software advanced to where the black box is no longer needed?
Old May 27, 2015 | 05:52 PM
GaryDoug's Avatar
Prominent Member
Re: Cable Question
Yes, the black box items have been replaced with an integrated circuit from FTDI that performs all the USB-to-serial port conversion needed. That IC resides on a small circuit board in one end of the cable, usually the USB plug end.
Old May 27, 2015 | 06:11 PM
Re: Cable Question
thank you. are all usb cables set up like that, or just the ones made special for aldl comm.? I've been away from this stuff for quite a while. lol
Old May 27, 2015 | 06:15 PM
GaryDoug's Avatar
Prominent Member
Re: Cable Question
Only the cables that perform a USB-to-Serial conversion. The ALDL cables are one type of those. USB-only cables do not have that circuit.
Old May 27, 2015 | 06:18 PM
GaryDoug's Avatar
Prominent Member
Re: Cable Question
These devices were originally designed to add back the serial port capability since the serial ports are no longer provided on newer pc's.
Old May 27, 2015 | 06:50 PM
Re: Cable Question
Thanks Gary, I appreciate your help!!
Parts Wanted
Mar 17, 2015 11:24 PM
edman
Jan 25, 2015 02:41 PM
pologreen97z
Dec 2, 2014 10:42 AM
Sarahrope64
Nov 27, 2014 11:17 AM
Jul 4, 2005 05:00 PM
