BTC29EAS Electrical Fault?
Old May 30, 2003 | 09:30 PM
slimdawson's Avatar
This test was done on a 1995 Formula. When it is in the loop it is fine. When it is out of the loop it hesitates. Any input would be great. Thanks in advance.
Old May 30, 2003 | 09:51 PM
madwolf's Avatar
DTC 29 is for a bad airpump. I'd start with checking the air pump fuse...
If that doesn't help, there's a recall on it and you can get it replaced at a dealership free.
Old May 31, 2003 | 02:15 AM
slimdawson's Avatar
I had my wife write this while I was at work so I will clarify.
When you first start the car, it is fine with no ses. It seems that when it switches to closed loop, the ses comes on and the fans as well. The owner complained of hesitation which I am blaming on the opti.
I will tell him to check the fuse and then call the dealer to see if his car has been recalled.
Thanks, Mike.
Old May 31, 2003 | 08:38 AM
SteveR's Avatar
It doesn't have anything to do with the recall. The problem most likely is rust/corrosion in the air pump. The pump will freeze up & blow the fuse, which sets the DTC. You can pull the pump apart & try to rebuild it, or just get a new one. Probably a lot of guys on this board have old working pumps sitting around...you might be able to find one that way.
You can just unplug the pump & put a new fuse in...the DTC will go away, but you won't have a pump.
Old May 31, 2003 | 08:49 AM
madwolf's Avatar
The premature internal corrosion was the reason for the recall. Why buy a used one when the dealership will install a brand new one at no charge?
Old May 31, 2003 | 09:12 AM
SteveR's Avatar
Please excuse my ignorance. I wasn't aware of the reason for the recall.
football4life
Oct 4, 2015 07:48 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
Daluchman1974
Sep 11, 2015 06:12 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
tdigger9899
Sep 7, 2015 10:56 AM
