Bought Diablo Predator Tuner - Need help
Old Aug 25, 2004 | 12:30 PM
TomH's Avatar
I just bought this for my 1999 Z28, but it has setting for the shift points and rev limiter and other stuff.
Can anyone give me a good set of data to use for my 1999 Z28.
(Shift points MPH and RPM's and shift rev limiter)
I have not tried it yet, but read the manual, do you have to program at
which RPM or MPH each gear shifts?
How about the rev limiter, what should that be set to?
Now the car has SLP intake, SLP exhaust (not loudmouth) and 3.73 gears.
They claim this tuner can be used for performance gains, but other that
resetting for the 3.73 gears, I am not sure where the performance gain comes from.
Old Aug 26, 2004 | 03:55 AM
AL SS590 M6's Avatar
Moderator
Re: Bought Diablo Predator Tuner - Need help
You'll have to use a gear/rpm calculator for that
Yes each shift is seperate. You might want to shift 1-2 at 6000 and 2-3 at 6150. It will take some playing to find out what your car likes. But the MPH has to match the rpm.
Stock valve train 6190-6200
It comes from loading the performance tune that's in the programmer. Then if that doesn't work well you can get e-mail tunes from various sources depending upon where you bought it.
Your welcome
jasonduaine
Apr 1, 2015 08:09 PM
grabbem88
Mar 25, 2015 12:09 PM
95chwagon
Feb 28, 2015 12:02 PM
99TransAmWS6
Jul 26, 2002 03:18 PM
